APR Performance Carbon Fiber Universal Hood Vents
jlacelica
Bericht door jlacelica » wo okt 09, 2013 07:43
Excessive heat can cause major and expensive damage to critical components in a car. Engine bays, radiators, brakes, transmissions, and differentials all need good air flow to help transfer away unwanted heat. APR Hood Vents help extract heat and reduce underhood pressure from the engine bay. By creating an outlet for hot air to be released, high velocity airflow can enter the engine bay to create a effective cooling system.
CF-100002, List €349/pair
CF-100004, List €349/pair
CF-214012, List €435
NACA-020825, List €115
NACA-032026, List €205/pair
Carbon Fiber Air Ducts
APR Air Ducts help bring fresh cooling air to different areas that need additional cooling.
NACA Duct Type 1
NACA-020825
NACA Duct Type 2
NACA-032026
Carbon Fiber Fender Vents
Turbulent and high-pressure air has a tendency to build-up in the wheel-wells. APR Fender Vents help to reduce the air pressure by providing an easy path for the air to escape. The air flow just outside the vents is fast-moving and low-pressure, and the APR Fender Vents provide an easy path for the turbulent wheel-well air to leave as smoothly as possible
2010-up Mustang
CF-214012
Universal Hood Vents Narrow
CF-100002
Universal Hood Vents Wide
CF-100004
John@JDMautoparts.NL
https://skydrive.live.com/?sc=photos&ci ... 6fda7a0URL" onclick="window.open(this.href);return false;
http://www.facebook.com/JDMautoparts.NL" onclick="window.open(this.href);return false;
