[PauluS87's Solarbeam Yellow Aygo][Update 2-7-2022 - Pag. 11]
Type Corolla: SE111
Re: [PauluS87's Corolla E11][Veel nieuwe updates, pag.2!]
Is die kleur trouwens Super Red 2 ?
zier er nog goed uit voor zijn leeftijd
PauluS87
Type Corolla: Toyota
Bericht door PauluS87 »
JDM20VAE101 schreef:Nice updates man!
Those rear disc conversion are from AE111?
looks very similar to mines.
did you change the proportioning valve?
Thank you! :D
I thought its from the G6R version, but i dont know for sure.. I did not change the proportioning valve, its fine for me. Braking is way better, but thats also because my rear brakes where all gone, hehe..
Bart-E11 schreef:Is die kleur trouwens Super Red 2 ?
Hey Bart! Hij is overgespoten in de kleur: Red Pearl Ablaze (Metallic) ;)
PauluS87
Gisteren scheen de zon heel mooi bij ons in Sneek! Even een paar fotootjes geschoten ;) Dan zien jullie ook direct de kleur tevoorschijn komen;
JDM20VAE101
Bericht door JDM20VAE101 »
I didn't change the prop valve too because I end up upgrading the fronts to a twin pot set up and that way the brake bias keep basically the same.
Man! that wheels looks very similar to the Tom's TN-10. I would like to get a set but now they are discontinued...
Looking good your E11!
Ivan's 4AGE BT 20V 6Spd LSD Shaved Tucked Engine Bay Build Thread
Just Click Here, Grab Some Beers, Scroll Down & Enjoy! :toost:
--->viewtopic.php?f=50&t=49611<---
Thanks For Looking! :D
PauluS87
JDM20VAE101 schreef:I didn't change the prop valve too because I end up upgrading the fronts to a twin pot set up and that way the brake bias keep basically the same.
They are not from Tom's, but look simular indeed :D And thank for the compliment
JDM20VAE101
you are welcome man!
what engine come with it?
PauluS87
Engine is just an: 4-AFE ;)
PauluS87
Volgende updates komen er binnenkort aan!
- Mistlampen zijn gemonteerd en werken! Foto's volgen nog,
- G6 bumper lip monteren + mee gespoten in kleur van de Corolla,
- Setje 3cm verlaging veren monteren.
Laatst gewijzigd door PauluS87 op ma dec 05, 2016 20:54, 1 keer totaal gewijzigd.
Luuk
Type Corolla: G6 20v
Re: [PauluS87's Corolla E11][Komende updates - Pagina 3]
Bericht door Luuk »
Mooi dat het gelukt is met de mistlampen! Moest je nog die andere kapjes hebben of paste het gewoon in je huidige bumper?
PauluS87
Hey Luuk!
Mistlampen paste gewoon netjes, even wat weg knippen uitde bumper en ze paste. Ik heb wel zelf beugeltjes moeten fabriceren waarin ik de mistlampen vast kon zetten in de bumper, en dat is netjes gelukt. Foto's volgen nog :)
PauluS87
Mistlampen die ik dankzij Luuk heb kunnen bemachtigen zijn gemonteerd!! :D
En toen kwamen mijn LED H4 lampen binnen! En de H3 LED lampen voor mijn mistverlichting!
Volgende updates:
Morgen (11-12-2016) gaat mijn Corolla 30mm naar beneden! En volgende week is mijn G6 lip klaar en ga ik die monteren!
jaapio
Type Corolla: XP9TS-MR2
Re: [PauluS87's Corolla E11][Mistlampen update - Pagina 3]
Bericht door jaapio »
sjun sjun.... :woow: :woow:
PauluS87
Re: [PauluS87's Corolla E11][Mistlampen + Verlaging - Pagina 3]
En de verlaging is ook mooi gelukt, met de pas geplaatste nieuwe schokdempers en 30mm verlaging veren;
Zo was de Corolla;
En het eind resultaat :D
Betere foto's van de Corolla komen nog ;)
jaapio
Ziet er beter uit..... :woow: :woow:
Geeft dat nu goed licht die led lampen?
PauluS87
Hey Jaap,
Die led verlichting is geweldig! Goed lichtbeeld en veel meer bereik dan halogeen! Deze heb ik besteld en geïnstalleerd:
https://www.aliexpress.com/item/1x-Pair ... 0.0.B0YTbC
Let er wel op dat je de passief gekoelde led verlichting neemt en niet de actief gekoelde (met een ventilator) want die dingen staan niet zo goed bekend als de passieve versies ;)
jaapio
Thanks...... ga me daar eens in verdiepen binnenkort. ;)
PauluS87
Betere foto van lampen met verlaging en 4 nieuwe winterbanden! :D (Snowtrack 5), ze rijden zeer degelijk!
jaapio
:woow: ....
PauluS87
Re: [PauluS87's Corolla E11][Leder Sportstuur Update! - Pagina 3]
Het stuur waar ik al heel lang naar op zoek ben, heb ik eindelijk in nieuw staat kunnen bemachtigen. Het stuur komt uit een Corolla met 70.000km! :D
Morgen denk ik dat ik hem ga monteren! 8-)
CCNL lidnummer: 855
Type Corolla: 4AFE Auto.
Bericht door Namssam »
Puik stuurtje kerel.
Ik heb er ook eentje ingemonteerd, en ik móet zeggen dat het zoveel meer rijplezier brengt.
Zelf had ik dat in eerste instantie niet verwacht (stuur = stuur) maar het ligt lekker in de hand en is ook wat sneller warm.
Nee, ik heb nooit gemoment spijt gehad van het kopen van EnricoG6R's stuurtje.
Het aansluiten / monteren is een peuleschil met de DHZ tip van Bart.
(je moet alleen een torque schroevendraaier hebben)
E11-4AFE '99 (van 2015 - 2024) In de verkoop.. :-(
Type Corolla: SE111
Het stuur vind ik zelf ook een hele verbetering
Ligt fijn in de hand en van veel mooier materiaal als dat standaard stuur
En alstublief!
CCNL lidnummer: 803
Type Corolla: corollag6r
Bericht door Peet »
Zit hier wel een airback in mannen ,het is zo klein allemaal
PauluS87
Vandaag een lekker dagje tijd genomen om dingen netjes te doen. :D
Al een hele tijd verloor mijn Corolla onnodig olie en sinds vorige week lag er toch wel heel veel olie in mijn motor ruimte. Het bleek de kleppen deksel te zijn die lekte.. Dus vandaag eerst de kleppendeksel eraf gehaald, alle resten van de vorige kleppendeksel pakking weggehaald,
Aan de rechterkant alles netjes schoon, aan de andere kant kun je de resten van de vorige pakking nog zien.. Er zat een vloeibare pakking tussen.
Alles daarna netjes voorbereid, en vernieuwd met een nieuwe kleppen deksel pakking en de overige pakkingen die bij het setje zat. En de kleppendeksel er weer op! (Nog nooit zo vaak het woord "kleppendeksel" gebruikt) :lol:
Direct daarna even met ontvetter en een hogedruk reiniger de motor ruimte netjes schoon gespoten;
En toen het stuurtje gemonteerd incl de airbag unit ;)
Ik ben weer helemaal happy en tot de volgende update maar weer! :D
Type Corolla: SE111
Re: [PauluS87's Corolla E11][Leder Sportstuur gemonteerd + Andere update! - Pagina 3]
Euhh water + verdeler kap geen goed idee
Kan je beter fles dasty rond spuiten 15m in laten trekken en met een gieter / vochtige doek af doen
Ziet er wel weer mooi proper uit
Ja peet zit een airbag in (welliswaar met terugroepactie)
Type Corolla: SE111
SV-Sportscars
Bericht door SV-Sportscars »
Terugroep actie voor deze stuurairbag? Nog niet eerder gehoord. De terugroepactie gaat normaal alleen om passagier airbag bij oa de Corolla.
Alle auto's die wij terug hebben laten roepen was puur de passagiers airbag en nooit dit model.
Over de auto ziet er netjes uit, maar wees inderdaad voorzichtig met een hogedrukspuit rondom electronica, als er water in komt kun je op termijn vervelende problemen krijgen.
PauluS87
Dankjewel voor jullie reacties!
Ik zal in het vervolg beter uitkijken voor de elektronica. Wel heb ik al heel erg opgepast dat ik geen elektronica onderdelen raakte met de hogedruk reiniger, maar ja het werd toch allemaal wel nat.. :)
jaapio
Leuk stuurtje.....zit ook in de MR2 :woow:
Perre
Type Corolla: E11Station
Bericht door Perre »
Ja, ik ben ook zeer grote fan van dit stuur. Het is net wat kleiner dan het standaard E11 stuur en het ligt veel beter in de hand.
PauluS87
Bedankt jongens!
Ik had niet verwacht dat na een dag met dit stuurtje gereden te hebben, het auto rijden nog leuker is! De auto ligt voor mij "gevoel" veel lekkerder op de weg!
En nu met het koude weer wanneer ik in de auto stap is het stuurtje een stuk minder koud dan het plastic stuur :lol:
